Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
disposition de ferraillage d'une semelle
6 REPLIES 6
madatana2012
1334 Views, 6 Replies
pouvez vous me donner comment diminuer le ferraillage du fût de cette semelle?
6 REPLIES 6
You can set the number of dowel bars in the dialog shown below:
In addition you can select some of them after their generation and then delete them freezing the reinforcement afterwards.
Artur Kosakowski
j'ai essayé d'imposer le nombre 1 et tjrs robot me donne la meme chose et le meme ferraillage??? c bizarre!!
Please send me your rtd file and make the screen capture that illustrates what you would like to achieve.
Artur Kosakowski
VOILA  MON FICHIER
It is assumed that the dowel bars should be generated in each corner of the pier/column and their number is pair. A single dowel bar seems bit unusual yet you can easily get what you want in the way shown on the attached picture.
Artur Kosakowski
DAC, je comprends qu'il faut supprimer des barres et translater le reste
