Discussion Groups
Robot Structural Analysis
Valued Contributor
fallright
Accepted Solution
display node numbers
407 Views, 6 Replies
09-06-2012 08:28 AM
I have 3 nodes and 1 bar.
The bar is from node 1 to 3; node 2 is in between.
When I turn on the node numbers, node number 2 isn't visible, also not the support symbol. (see attachment)
Why is this ? I work with RSA 2013.
Is this a setting ?
Please use plain text.
Product Support
pp2008
Re: display node numbers
09-06-2012 09:01 AM in reply to: fallright
Can you attach the RTD file (compressed to ZIP)?
Pawel Pulak
Valued Contributor
fallright
09-06-2012 11:12 PM in reply to: pp2008
In attach the RTD-file.
I've found a "work-around" to solve my problem, but I think this can be better in a next version.
First I had 2 nodes ("1" and "2"). Then I added node "3". Then I changed in the TABLE bars "node2" in "3".
See example2.jpg.
So if you change this back in "2" and then back in "3", you will see that node "2" is'nt displayed in the view-window.
Product Support
pp2008
09-07-2012 02:15 AM in reply to: fallright
This display effect is related to active "Filter Structure Stories" active for Building Design structure type.
It is enough to switch off this filtering.
See this video illustrating it: http://screencast.com/t/SkBNVXIEEEfY
The suggestion to improve this behavior registered:smileyhappy:
If this post answers your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Valued Contributor
saclovitzky
06-13-2013 03:49 AM in reply to: pp2008
I have the same problem, the "nodes" are not visible but their numbers are. I really do not know why I cannot see the nodes, regarding the explanation of pawel it is not really clear to me what he meant. Any comment(s) will be appreciated.
Product Support
Rafal.Gaweda
06-13-2013 07:32 AM in reply to: saclovitzky
Ramon
-        Things with stories as suggested by Pawel
-        Or display for selected objects on
-        Or hide node on
-        Or Fes display off
-        Or try to turn off filling of panel interior display
Rafal Gaweda
Valued Contributor
rioja
06-17-2013 05:51 PM in reply to: Rafal.Gaweda
Ramon
the nodes are not visible because they "belong" to another story and the story is not visible, do what Pawel says and look for details for Rafals description
