Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Display bar length graphically
14 REPLIES 14
Message 1 of 15
sorgjee
1561 Views, 14 Replies
Is there any way of displaying the bar lengths graphically on the screen through the current display options implemented in Robot?
This is primarily for the element length, but if possible to dusplay minor and or major axis buckling lengths that would be very useful as well.
If not possible directly in Robot, is there a way of using a VBA macro to have the API generate a custom display option?
14 REPLIES 14
Message 2 of 15
Rafal.Gaweda
in reply to: sorgjee
Not possile.
Only when you hoover mouse over bar you can check bar length on robot status bar:
Turn on LCS display - only.
UNfortunatelly not possible.
Rafal Gaweda
Message 3 of 15
Artur.Kosakowski
Sorgjee,
Mind that a buckling length is not the definition that returns a single value for the whole bar. Using more advanced definition of the parameters this depends on where the verification point is actually located. In addition there are two other options to check what the bar length is.
Artur Kosakowski
Message 4 of 15
sorgjee
in reply to: Artur.Kosakowski
Rafel/Artur,
Thanks for the feedback, but unfortunately displaying the length on-screen is not sufficient. We need to output illustrations for a large number of trusses, showing the length of the individual members.
Assuming the name of the elements be set to a value that does not include the bar number when using the API, do you think it would be possible take a collection of all the bars in the model, loop through them and do set bar(i).Name = bar(i).Length & "m" (or is this impossible if Name is ReadOnly)? Once this is done, the normal display showing bar names should output it.
Message 5 of 15
Romanich
Hi
Just look at the picture:
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 6 of 15
sorgjee
in reply to: Romanich
Bingo! Give the man a sweet. 🙂
Not an ideal solution, but a good workaround to the main problem. Have to reset the scale continuously for some reason, but otherwise working.
Thanks.
Message 7 of 15
Rafal.Gaweda
Unfortunatelly bar.Name is read only attribute.
Yuo can not set it with API.
Rafal Gaweda
Message 8 of 15
Rafal.Gaweda
in reply to: Rafal.Gaweda
API code to display what Romanich suggested:
Dim viewRobot As IRobotView3 ' this is important to set IRobotView3 if you want to make screen capture of this view
' Set viewRobot = RobApp.Project.ViewMngr.CreateView(1)
Set viewRobot = RobApp.Project.ViewMngr.GetView(1) ' it seems CreateView makes strange affect, use GetView instead
viewRobot.ParamsBarMap.CurrentResult = I_VBMRT_DESIGN_MEMBER_LENGTH
viewRobot.ParamsBarMap.Descriptions = I_VDDT_TEXT
viewRobot.ParamsDisplay.SymbolSize = 3
RobApp.Project.ViewMngr.Refresh
Rafal Gaweda
Message 9 of 15
Rafal.Gaweda
KInd of workaround - generating and assigning section names=bar lengths
(do it on dummy model or re-assign correct sections at the end)
Dim RLabel As RobotLabel
Dim OriginalSectionName() As String
Dim BLen As String
Dim RBar As RobotBar
Dim BarCollection As RobotBarCollection
Set BarCollection = RobApp.Project.Structure.Bars.GetAll
ReDim OriginalSectionName(BarCollection.Count) As String
For I = 1 To BarCollection.Count
Set RBar = BarCollection.Get(I)
BLen = Str(RBar.Length)
OriginalSectionName(I) = RBar.GetLabelName(I_LT_BAR_SECTION)
Set RLabel = RobApp.Project.Structure.Labels.Create(I_LT_BAR_SECTION, BLen)
RobApp.Project.Structure.Labels.Store RLabel
RBar.SetLabel I_LT_BAR_SECTION, BLen
Next I
viewRobot.ParamsDisplay.Set I_VDA_SECTIONS_NAME, True
'make screen capture or whatever here on this display
'restoring original names
BarCollection.Get(I).SetLabel I_LT_BAR_SECTION, OriginalSectionName(I)
Next I
Rafal Gaweda
Message 10 of 15
sorgjee
Thanks, the code for the mapping works for me, except the symbol size is refusing to change frmo anyting other than 3. ANy idea what is causing this?
Is there a way of setting the scale colours to black through the API? Trying to make the print as neat as possible.
Message 11 of 15
Rafal.Gaweda
(Keep in mind that this approach may not display member lengths on all members - take a look at Romanich screen shot)
Do you refresh after?
I am afradi not possible.
Try this code :
viewRobot.ParamsBarMap.MapThicknessCoeff = 1
viewRobot.ParamsDisplay.SymbolSize = 5
viewRobot.ParamsDisplay.Set I_VDA_VIEWOGL_BLACK_EDGES, True
Rafal Gaweda
Message 12 of 15
sorgjee
Hi Rafal,
Thanks _BLACK_EDGES works a treat.
No idea about why the SymbolSize is not working . Was running smoothly last night. Will try different computer and see if it makes any difference.
One more question though, after setting BarMap, how do I revert to a 'normal' view. Using ParamsBarMap.CurrentResult - I_VBMRT_NOTHING simply makes the bars disappear completely.
Even
Message 13 of 15
sorgjee
I tried SymbolSize on a different computer (with RSA2012), and it worked fine. Still no luck on this computer, which has RSA2011 installed. The reference manual indicate that this function was introduced fairly early so should work. Any idea?
Message 14 of 15
Rafal.Gaweda
You are right. On 2011 the change of this parameter makes no difference on display.
Works fine on 2012.
Rafal Gaweda
Tags (1)
Message 15 of 15
Rafal.Gaweda
This should work:
viewRobot.ParamsBarMap.Descriptions = I_VDDT_NONE
viewRobot.ParamsBarMap.CurrentResult = -1
viewRobot.ParamsDisplay.Set I_VDA_VIEWOGL_BLACK_EDGES, False
Rafal Gaweda
