Is the displacments i the stories tabel UX/UY the displacement of the gravity center?
Are the dx/dy value for the i'th flor the differense between the the i'the flore in x/y dir. and the i-1 flor. eg. [d=(ui)-(ui-1)]
Are the displacments multiplied with the q when i have not spessified one.. eg. q=1,5
And are the redused forces the sum of all forces in a storie redused to the gravity center?
best regards
Please check :
and let me know if anything needs any further explanation.
I have had a look at it, and i am wondering about the Ux and UY
The max Ux and Uy ar det maximum dispacments in X and Y- dir,
the Drift of storries ar det diffrenses in displacements of the sumsecent storries
But are the Ux and Uy calculated in the same matter as the UxF as stated in the link you gave me.
ore are they calculated as the sum of the dispacemets divided by the number of calculation points?
best reggards
Story Drift is calculated basing on UF value, averaged floor displacement UX or UY , which is weighted by the elements mass as UX = SUM(i) (UXi * Wi) / SUM(i) Wi
