Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Different moment of inertia
4 REPLIES 4
693 Views, 4 Replies
I am trying to calculate the moment of inertia of a section with additional stiffener plates. I have attached the section I am trying to imput into the section definition.
The profile is aluminium with steel plates. When I calculate I get different values than robot. Can you please explain?
A quick reply would be appreciated
4 REPLIES 4
marcinrakus
I briefly ran through manual calculations at attached pdf I did not come up the modification of moments of interia of particular parts to the new center of gravity of combined section (using Steiner theorem).
Rafal.Gaweda
in reply to: marcinrakus
Just one hint: all results with * are weighted results calculated with respect to base material set on first tab.
Rafal Gaweda
in reply to: Rafal.Gaweda
Thanks Rafel,
So you think the manual calculations are incorrect and I should use Robot?
The value with * is the moment of inertia I should be using then as this is the equivalent aluminium section (combined aluminium and steel)?
D
Rafal.Gaweda
I am afraid your hand calculations are too simple or I do not see part of it.
for example Iytotal = Iym + n*Iyst1 + n* Iyst2
But you use these values as calculated for each separate part but you need to transform them to center of gravity of whole section before adding.
Rafal Gaweda
