I am trying to calculate the moment of inertia of a section with additional stiffener plates. I have attached the section I am trying to imput into the section definition.
The profile is aluminium with steel plates. When I calculate I get different values than robot. Can you please explain?
A quick reply would be appreciated
I briefly ran through manual calculations at attached pdf I did not come up the modification of moments of interia of particular parts to the new center of gravity of combined section (using Steiner theorem).
I am afraid your hand calculations are too simple or I do not see part of it.
for example Iytotal = Iym + n*Iyst1 + n* Iyst2
But you use these values as calculated for each separate part but you need to transform them to center of gravity of whole section before adding.
