Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
different area values for model calculation and member verification
7 REPLIES 7
Message 1 of 8
247 Views, 7 Replies
Is there a way to perform stresses and displacements calculations with one value of the area, but for the member verification maintain the original area??
I have to perform stress and displacements considering only the 5% of the area for a certain section while for the bar verification I have tu use normal area.
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
Do you mean steel design?
Artur Kosakowski
Message 3 of 8
in reply to: Artur.Kosakowski
yes
Message 4 of 8
Artur.Kosakowski
1. Calculate a model with a section you want to use for static analysis
2. Create a steel design group with the bar list containing the bar you are checking and assign it the profile you want to use for ULS verification (Group 1)
3. Create a steel design group with the bar list containing the bar you are checking and assign it the profile you want to use for SLS verification (Group 2)
4. Run the code group design for ULS for the group 1
5.  Run the code group design for SLS for the group 2
Artur Kosakowski
Message 5 of 8
Despite this way could be solve the problem. I think should be implemented somewhere a box where indicates the % of the section for the analysis and the design.
Message 6 of 8
Artur.Kosakowski
Do you mean similar option to the one available for RC sections?
Artur Kosakowski
Message 7 of 8
I don't work with RC. Only Steel, so I can not say.
Message 8 of 8
Artur.Kosakowski
Like that plus AX field ?
Artur Kosakowski
