Hi
I want to use a diagram illustrating the vertical load applied to a wall.
So far, I have only been able to use maps and thick of membrane forces.
Moreover, I want to find an average value or integral value.
Can someone please help me with this?
Kind regards
Peder
Solved by Artur.Kosakowski. Go to Solution.
Peder,
Could you attach a sketch which illustrates what the diagram should look like please?
Hi
I diagram looking like this would be nice
Is that possible?
Regards
Peder
Thanks Artur.
Would it be to much to ask if you could make a short video illustrating how you would do this in structure type 'Building design'?
One reason I want to check these values is to investigate the minimum thickness of a wall in regards to just compression.
