Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Determination de la charge lineaire.
1 REPLY 1
FabriceMendelski3705
364 Views, 1 Reply
Bonjour,
quelle est la procedure à suivre pour obtenir une charge lineaire donc en T/ml sur une semelle filante. structure réalisée sur robot coque ( voir PJ).
 Merci d'avance.
1 REPLY 1
Contrary to the first calculation method in CBS you are also using Robot does not use the load takedown approach therefore instead of load from the tributary are you will see the results in form of internal forces such as bending moments, shear forces etc.
Artur Kosakowski
