Bonjour,
quelle est la procedure à suivre pour obtenir une charge lineaire donc en T/ml sur une semelle filante. structure réalisée sur robot coque ( voir PJ).
Merci d'avance.
Solved by Artur.Kosakowski. Go to Solution.
Contrary to the first calculation method in CBS you are also using Robot does not use the load takedown approach therefore instead of load from the tributary are you will see the results in form of internal forces such as bending moments, shear forces etc.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
