Detailed Structure Correction
6 REPLIES 6
Romanich
834 Views, 6 Replies
Hello friends,
I'm tried to make some correction by using Detailed Structure Correction option. But nothing happens.
Can you explain in detail how to use this option?
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Tags (1)
6 REPLIES 6
Rafal.Gaweda
in reply to: Romanich
too small Precision - must be bigger than mentioned distance
Rafal Gaweda
Romanich
in reply to: Rafal.Gaweda
Rafal, I've used from 0.00001 to 100 m and no results in any case.Smiley Sad
Roman Zhelezniak
Rafal.Gaweda
Rafal Gaweda
Romanich
Maybe I'm dumb, but this option don't work in my hands. Also, i'm read help, but...
Roman Zhelezniak
Rafal.Gaweda
Movie: http://screencast.com/t/5kyKHjCBfK
Rafal Gaweda
Romanich
Thank you, Rafal.
The algorithm is not worked like I'm thought.
Also, in Russian language help, this string "Structure corrections are performed only then when the distance is smaller than precision" is absent.
Roman Zhelezniak
