Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Design Results
1 REPLY 1
Mohammed_Ata
643 Views, 1 Reply
Design Results
i've modeled a 10 stories building .
i selected 1 column to design - RSA moves to RC Elements module and design it and designs it but , when i move to the main structure again - and select the same column to design it , RSA designs it as the first time !!
doesn't RSA save the design results for elements ?
1 REPLY 1
If you import it again it is understood that you want to overwrite the previous design. Just double click on the already designed column in the RC Inspector instead.
Artur Kosakowski
