i've modeled a 10 stories building .
i selected 1 column to design - RSA moves to RC Elements module and design it and designs it but , when i move to the main structure again - and select the same column to design it , RSA designs it as the first time !!
doesn't RSA save the design results for elements ?
Solved by Artur.Kosakowski. Go to Solution.
If you import it again it is understood that you want to overwrite the previous design. Just double click on the already designed column in the RC Inspector instead.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
