In the module for the manual assembly of beams has detected the following problem: After entering the armors and calculated the beam, the program does not consider the lower reinforcement in the beam resulting in that section and that does not meet resistance bending moments positvos to zero .. When going to see the diagrams of results in the corresponding flange concrete reinforced module shows that diagrmas not appear in the bottom of the graph corresponding to the resistance due to the lower positive reinforcement
Could you send the rtd file with such beam? How the reinforcement was created - generated by Robot or using the typical reinforcement dialog? Other way?
Thank you.
The reinforcement has been created using the typical reinforcement dialog.
Please find attached the .rtd file with the beam. The file has been zipped in order to send it to the discussion group.
Regards.
Follow the steps shown on the attached picture.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Tahnk you.
We tried your solution but the problem persists.
Attached is a picture with the armed beam diagram.
Regards.
http://screencast.com/t/6B08ILGgR
We are unable to do the same as on your video. We have tested three worksation with Robot.
We are using Robot 2013 and Windos 7 64 bit on a Dell Optiplex 380.
Thank you.
Send me the rtd file and a picture that shows the actual issue please.
As far as I can see the diagram is displayed correctly when you first freeze reinforcement and then launch calculations as shown on the attached picture.
Try to install SP3 for Robot 2013 from:
After installing the service pack 3 and hot fix 4 the problem has been solved.
Thank you.
Regards.
