Discussion Groups
Robot Structural Analysis
Active Member
0 Kudos
DESIGN - RC BEAMS - Armed Beams
423 Views, 10 Replies
01-23-2013 03:28 AM
In the module for the manual assembly of beams has detected the following problem: After entering the armors and calculated the beam, the program does not consider the lower reinforcement in the beam resulting in that section and that does not meet resistance bending moments positvos to zero .. When going to see the diagrams of results in the corresponding flange concrete reinforced module shows that diagrmas not appear in the bottom of the graph corresponding to the resistance due to the lower positive reinforcement
Product Support
758 Kudos
Re: Armed Beams
01-23-2013 03:50 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
Could you send the rtd file with such beam? How the reinforcement was created - generated by Robot or using the typical reinforcement dialog? Other way?
Artur Kosakowski
Active Member
0 Kudos
Re: Armed Beams
01-23-2013 04:36 AM in reply to: Artur.Kosakowski
Thank you.
The reinforcement has been created using the typical reinforcement dialog.
Please find attached the .rtd file with the beam. The file has been zipped in order to send it to the discussion group.
Regards.
Product Support
758 Kudos
Re: Armed Beams
01-23-2013 05:09 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
Follow the steps shown on the attached picture.
Artur Kosakowski
Active Member
0 Kudos
Re: Armed Beams
01-24-2013 09:27 AM in reply to: Artur.Kosakowski
Tahnk you.
We tried your solution but the problem persists.
Attached is a picture with the armed beam diagram.
Regards.
Product Support
758 Kudos
Re: Armed Beams
01-25-2013 01:20 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
http://screencast.com/t/6B08ILGgR
Artur Kosakowski
Active Member
0 Kudos
Re: Armed Beams
02-13-2013 06:19 AM in reply to: Artur.Kosakowski
We are unable to do the same as on your video. We have tested three worksation with Robot.
We are using  Robot 2013 and Windos 7 64 bit on a Dell Optiplex 380.
Thank you.
Product Support
758 Kudos
Re: Armed Beams
02-13-2013 06:28 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
Send me the rtd file and a picture that shows the actual issue please.
Artur Kosakowski
Active Member
0 Kudos
Re: DESIGN - RC BEAMS - Armed Beams
02-13-2013 09:08 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
The .rtd and image you requested.
regards.
Product Support
758 Kudos
02-14-2013 02:02 AM in reply to: ALEJANDROFELGUEROSAFUENTES1370
As far as I can see the diagram is displayed correctly when you first freeze reinforcement and then launch calculations as shown on the attached picture.
Try to install SP3 for Robot 2013 from:
Robot2013SP3
Artur Kosakowski
