Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Design of inclined elements
1 REPLY 1
andrea_pontiggia
657 Views, 1 Reply
hi, I wanted to know if there is a way to export the designs of the armor elements inclined Robot, also with AutoCAD Detailing. Thanks in advance
Andrea
1 REPLY 1
The inclined beam reinforcement export to ASD is not supported. You can try the following solution:
Window > Add View > Beams > Beam Reinforcement Edition  and save the generated drawing as dxf/dwg
Mind that this is going to be an ASD file but a vanilla AutoCAD dwg instead.
Artur Kosakowski
