Kindly, I need the methodolgy of using robot for design of core wall
Solved by Artur.Kosakowski. Go to Solution.
Assuming you want to calculate reinforcement there are two options:
1. Use RC Panels Reinforcement module
2. Use RC Wall reinforcement module (currently available codes are BAEL, EC2 and ACI).
Hello Artur
"Assuming you want to calculate reinforcement there are two options:
- How will I view the reinforcement maps for the walls?
2. Use RC Wall reinforcement module (currently available codes are BAEL, EC2 and ACI)."
RAmon
The same as for panels \ slabs required reinforcement module \ maps.
I think I might have asked this question before, but does one group the core walls by stories or is the core wall group the whole stack (i.e. over multiplie stories)?
As far as I understood you correctly - define core walls as a whole stack (but each wall not as a one panel - several panels from story to story level)
Thanks, If I understand correctly, the core wall is defined by selecting all the panels making up the core wall (eg. C-, or L- shaped) over multiple levels and defining all these as 1 core wall
there I intent to use ROBOT result to deign core wall manually.
my question:
about the value of the moment WMX &WMY based in which coordinate should be considered.
OR shall I considered big value for major axis for the wall?
as I got some un explanation value
Is there a way in robot to provide reinforcement for a whole corewall, not for each wall of it separately?
Hi @ramy_habchi
No, there is no such option in Robot.
If I managed to answer your question(s) press the Accept as Solution button please. This will help other users to find solution(s) much faster. Thank you.
The results for core walls are in the global coordinate system.
If one or more of these posts answered your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Hello!
ROBOT isn't giving me reactions for this core wall. It is the only core wall group where there's no result shown.
Hello!
I think this has been resolved. What I did was attach the core wall to the slab above by reducing the opening size so there's a very slim wall pier connecting the two.
