Design colum Steel of Robot
12 REPLIES 12
Message 1 of 13
athurD
922 Views, 12 Replies
Hi. I want creative frame Zamil of robot same picture . I is attachments
12 REPLIES 12
Message 2 of 13
Romanich
in reply to: athurD
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 13
athurD
in reply to: Romanich
Thanks you Romanich.
You can help me next Picture???
Thanks you verry much.
Message 4 of 13
Romanich
in reply to: athurD
Also, you can use shells for column:
Roman Zhelezniak
Message 5 of 13
athurD
Oh Good idie.
Thanks.
But do shell can connection same steel.???
Message 6 of 13
Romanich
in reply to: athurD
Sorry, but I didn't understand your idea.
Also, if you want use tapered bar with one vertical flange, try to use Offset option. But note, as an Artur wrote - bar element is just the line that represents the center of the section with assigned attributes such as profile type.
Roman Zhelezniak
Message 7 of 13
athurD
Thanks You Romanich
Hi. You can toturial creative frame same picture???
Please tutorial video. Thanks you verry much
Message 8 of 13
athurD
in reply to: athurD
Please !!
Message 9 of 13
athurD
in reply to: athurD
Please help me !!
Message 10 of 13
Artur.Kosakowski
in reply to: athurD
Artur Kosakowski
Message 11 of 13
huyxp
in reply to: athurD
can you write tutorial for example frame.zip in message 10 please???
thank you
Message 12 of 13
athurD
in reply to: huyxp
Hi.
please check message 4.
Message 13 of 13
huyxp
in reply to: athurD
HI thank you very much but i think steel in message 4 modeling as solid ??
i use method in message 10 in link below
http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Column-with-section-change/td-p/3434495
please help me thank
modeling column steel in industrial building
