When I want to modify a solid (created by extruding a panel-face), the only way to do is delete the solid (which is indicated as volumetric object), and recreate it.
But when deleting a this volumentric object, the attached nodes are also deleted automaticly, including all supports.
How can I prevent these nodes to be deleted also?
I've tried to move the solid first away from the nodes, but even with a gap of 10meters the nodes are still connected anyway.
Please help.
Solved by Rafal.Gaweda. Go to Solution.
Sorry, I didn't understand your answer.
I've tried to move the solid away from the nodes, but then also the nodes are deleted automaticly when the solid is deteled.
What is the workaround you suggest?
No, that doesn't help also. Moving the nodes away, will not prevent them from auto-deleting them.
Any suggestions?
