Hi all
as a part of my wish list
It is possible to add the following information on the final drawings?
1 The max. deflection values and its location for each span on the final drawings
2 The element numbers or only column numbers (in blue) and or the column name like CC_30 or CR30x20
Best Regards
Marcelo
Could you make a sample of such drawings and send them please? Thank you.
Hi Artur
Attached you will find a final drawing with a description that can be useful for the constructors
This should be done for every span
The example is composed by only 1 span
The numbering of the columns will help us for easier recognition from the side in which the final drawing was drawn
Honestly this is the first time I have heard about the need for information about beam deflection being shown on the shop work drawings. My assumption is that at the design stage you have to secure that all SLS requirements are fulfilled which means the defelction of the beam (or each of its span) is kept under control (is within the imposed limits) so there is no further concern about this issue. Is it a particular code / country request?
Question to others: any other code or country that requests this too?
For names of the column (supports) you can name them the way you like as shown on the attached picture.
