Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Deformation in the modalanalysis
8 REPLIES 8
Message 1 of 9
774 Views, 8 Replies
Hi
I have made a modal analysis of a structure. The modal deformations shapes are illustrated on the Pdf file.  The deformations only moves in one direction and then back to initial rest position. I would assume that oscillation would move in both directions relative to the initial position of the structure.
How can I make an animation, which illustrates that, the deformations from the oscillations moves in both directions?
Best regards
Birgitte
8 REPLIES 8
Message 2 of 9
jad.dellel
You should change the mode selected to see the modal deformation in the other direction, generally:
mode 1 illustrates translation of the structure / X
mode 2 illustrates translation of the structure /Y
mode 3 ..... rotation ... /Z
Jad DELLEL
Sustainability Success Manager - Autodesk, Inc.
Message 3 of 9
jad.dellel
Select modes-> switch ON modes + All + accept and run your animation as usual.
Jad DELLEL
Message 4 of 9
in reply to: jad.dellel
Hi Again
Thank you very much for the answer. I have now made an animation of the combined 3 first modes. I have attached a screen shot of the combined deformation (see attached file).
-           Is it supposed to look like that, where the individual bar elements devide from the rest of the structure?
-          Also I thought that it would be possible to illustrate first total downwards movement, and after that total upwards movement, so the structure would oscillate up and down.  In the combined modal-case, all elements move in different direction at the same time.
-          Just to clarify is the next 3 modes (mode 4-6) illustrating the second combined oscillation-shape… and so on?
Thank you
Birgitte
Message 5 of 9
Pawel.Pulak
Hi Birgitte,
it seems that there was some misunderstanding when answering this post:
1/ deformations from different modes should not be combined
2/ as for now it is not possible to display in RSA the animation of vibration shape showing it for full vibration period (both positive and negative aplitudes in all points). The animation is showing only one half of the vibration period - opposite directions of harmonic vibrations are not shown. Implementing such functionality in on the wish list for some timeSmiley Sad
Pawel Pulak
Technical Account Specialist
Message 6 of 9
jo2ny
in reply to: Pawel.Pulak
Somehow close to the subject:
Is is possible, when visualising the deformed shape of a mode, to display the period instead of the frequency?
(I'm using ARSA Pro 2012 )
Message 7 of 9
Artur.Kosakowski
in reply to: jo2ny
No, that is not possible.
Artur Kosakowski
Message 8 of 9
jo2ny
in reply to: Artur.Kosakowski
Thanks. Maybe in a future version?
In our country we commonly use period instead of frequency as the response spectrum has periods on the X-axis and it's quicker to classify the vibration of the first mode (between (Tb;Tc) (Tc;Td), greater than Td. etc.)
Message 9 of 9
Artur.Kosakowski
in reply to: jo2ny
I have made such development request.
Artur Kosakowski
