Discussion Groups
Robot Structural Analysis
Active Contributor
tord
Accepted Solution
deflection smaller in a heavier loadcase
188 Views, 2 Replies
01-03-2014 05:59 PM
Hello ARSA support
How come that the slab-deflection is smaller in a heavier loadcase.
In Eurocode 1990 and 1992-1-1 (Concrete) we use to calculate deflections either in characteristic loadcase (6.14b) or in frequent loadcase (6.15b).
We calculate cracks in quasi-permanent loadcase (6.16b).
In my calculation I have 2.6mm deflection in loadcase 6.15b and 16.9mm in loadcase 6,16b which is lighter.
See attachments.
Thanks / Tord
Please use plain text.
Product Support
Rafal.Gaweda
Re: deflection smaller in a heavier loadcase
01-07-2014 03:07 AM in reply to: tord
Combination 20 should be set as QPR to properly calculate reinforcement - as written in warning message.
Rafal Gaweda
Active Contributor
tord
01-07-2014 11:03 AM in reply to: Rafal.Gaweda
Thank you Rafal, but how about the deflection?
I want to test the deflection, with the new choice of reinforcement, to another loadcase.
In this case it´s a tiny difference, but i some cases for deflection the liveload will be multiplied with 0,7 and for Quasi (crack´s) with 0,3, then the difference will be considerable.
Tord
