Show only
Search instead for
In the attached file, when I display deflections under Results/Maps I get positive deflections under all applied loads. When I look at the deflected shape I can see the deflections are downwards (i.e. negative Z) so I would like to see a negative deflection. Is there a way to change the setting so the deflections become negative when I display them as described above?
