Discussion Groups
Robot Structural Analysis
Valued Contributor
Jesper.Jensen
Deflection Settings
230 Views, 1 Replies
11-11-2012 08:47 PM
In the attached file, when I display deflections under Results/Maps I get positive deflections under all applied loads. When I look at the deflected shape I can see the deflections are downwards (i.e. negative Z) so I would like to see a negative deflection. Is there a way to change the setting so the deflections become negative when I display them as described above?
http://wtrns.fr/PlSFa4ne2e2xACk
Thanks in advance,
Jesper
Please use plain text.
Product Support
Artur.Kosakowski
Re: Deflection Settings
11-12-2012 12:27 AM in reply to: Jesper.Jensen
Jesper,
Delete the mesh from panel 8 and mesh the panel again.
Artur Kosakowski
