In the attached file, when I display deflections under Results/Maps I get positive deflections under all applied loads. When I look at the deflected shape I can see the deflections are downwards (i.e. negative Z) so I would like to see a negative deflection. Is there a way to change the setting so the deflections become negative when I display them as described above?
http://wtrns.fr/PlSFa4ne2e2xACk
Thanks in advance,
Jesper
Solved by Artur.Kosakowski. Go to Solution.
Jesper,
Delete the mesh from panel 8 and mesh the panel again.
