Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Deflection Settings
1 REPLY 1
439 Views, 1 Reply
Deflection Settings
In the attached file, when I display deflections under Results/Maps I get positive deflections under all applied loads. When I look at the deflected shape I can see the deflections are downwards (i.e. negative Z) so I would like to see a negative deflection. Is there a way to change the setting so the deflections become negative when I display them as described above?
http://wtrns.fr/PlSFa4ne2e2xACk
Thanks in advance,
Jesper
1 REPLY 1
Artur.Kosakowski
Jesper,
Delete the mesh from panel 8 and mesh the panel again.
Artur Kosakowski
