Hi I want to be know what the deflection is in a slab with provided reinforcement. In the provided reinforcement module it gives the deflection map for required reinforcement but the option for "provided reinforcement after verification" is greyed out, see attached picture. How do I do this?
Many thanks.
Solved by Rafal.Gaweda. Go to Solution.
Ok found the verification button. One of the easier questions you have to answer no doubt 😉
Am I correct that that is the final deflection including creep where as the deflection given in Results > Results - maps is elastic deflection?
Results > Maps is elastic deflection
You can use the Analysis>>>Verification. Please find the attached file.
