Deflection for provided reinforcement
4 REPLIES 4
703 Views, 4 Replies
Hi I want to be know what the deflection is in a slab with provided reinforcement. In the provided reinforcement module it gives the deflection map for required reinforcement but the option for "provided reinforcement after verification" is greyed out, see attached picture. How do I do this?
Many thanks.
4 REPLIES 4
Rafal.Gaweda
"... after verification"
Have run Verification of Provided Reinforcement ?
Rafal Gaweda
in reply to: Rafal.Gaweda
Ok found the verification button. One of the easier questions you have to answer no doubt 😉
Am I correct that that is the final deflection including creep where as the deflection given in Results > Results - maps is elastic deflection?
Rafal.Gaweda
Results > Maps is elastic deflection
Rafal Gaweda
HoshangMustafa
You can use the Analysis>>>Verification. Please find the attached file.
