Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Deflection Calculation on robot extension sheet 2013
0 REPLIES 0
Message 1 of 1
faisal.aaouatif
285 Views, 0 Replies
Im trying to use the module "Calcul de la flèche fissurée d'une poutre" under Robot Extension sheets 2013 , but i dosent obtain correct values of deflection. (under Bael 99 - old french code )
With the example attached, as a background , i should have a deflection close to 8.8 mm. (page 4/4)
I used the same example on another free programm version (from a Known controler office) , i had exatly the same value of deflexion (8.89mm).
Help appreciated.
0 REPLIES 0
