If a Robot model was built using a revit file, and material properties are missing for a series of trusses, is there a way to define the material properties in Robot?
Solved by Artur.Kosakowski. Go to Solution.
You can assign materials either to a section label or to a selected bar(s) using the Materials dialog or in the Bars table.
