Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Define mass source of Robot Analysis
8 REPLIES 8
Message 1 of 9
A.wikipedia
1621 Views, 8 Replies
Hey all.
I find Define mass source of Robot.
 So Where it is of robot.
Of Etabs.
8 REPLIES 8
Message 2 of 9
Romanich
in reply to: A.wikipedia
You can use search engine on this forum and also look at this thread http://forums.autodesk.com/t5/Autodesk-Robot-Structural/Conversion-load-to-mass/m-p/3050232#M160
And don't forget to use help!
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 3 of 9
Bassamlubbad1
in reply to: Romanich
Dears:
First I want to thank you for your clarification to the mass source definition
I just have question if you dont mind,
In mass source definition we normally (In Etabs) add
1-Self weight
2-Super imposed dead load
3-Percentage of live load
is it the same in Robot?
and also how can I show the " Auto seismic loads calculations" in order to know the exact weight considered?
as it exist in Etabs
Appreciate your support
Message 4 of 9
Dears:
1-Self weight
is it the same in Robot or am just adding super imposed dead loads & percentage of live loads only as the SELF WEIGHT is assigned automatically?
and also how can I show the " Auto seismic loads calculations" in order to know the exact mass considered?
Message 5 of 9
pavlosth
in reply to: Bassamlubbad1
In general, you do not have to define the mass of the frame, as it is automatically calculated from Robot. So only add superimposed dead and the percentage of the live loads that you want to assume for earthquake.
Perhaps if you set the mass of the material to zero, or if you delete the first loadcase that by default is assigned with the self-weight and mass of the structure, you have to manually insert the mass, but I never have attempted such a thing.
To check the mass, select "Modal Analysis Results" from the tables and you can see the total mass of the structure.
Message 6 of 9
Hi @Bassamlubbad1
1-Self weight
The self weight is by default considered automatically for the other load types you can convert them into masses with the corresponding factors in the dialog infiocated bu @Romanich (thank you for helping out)
Assuming you refer to the value of mass considered for seismic analysis it is diapered in the results of the modal analysis table or in the calculation note.
I'd strongly recommend watching the recording of the Introduction to seismic and spectral analysis Robot webinar.
Artur Kosakowski
Message 7 of 9
Artur.Kosakowski
in reply to: pavlosth
Hi @Bassamlubbad1
I just wanted to check if you received the information you were looking for.
Artur Kosakowski
Message 8 of 9
Dears:
I really appreciate your professional support as usual
Message 9 of 9
Hi @Bassamlubbad1
Thank you on behalf of all of us participating in this thread Smiley Happy
Would you mind marking this thread with the Accepted solution so that others could find answer on the similar question they may have in the future faster? Thank you.
Artur Kosakowski
