dead weight with a coefficient
7 REPLIES 7
Message 1 of 8
mateaus
460 Views, 7 Replies
How can I create this load with Robot API ?
I would like the load of dead weight with a coefficient.
10:charge verticale poids propre 1A5 Partie de la structure -Z Coef=0.20 MEMO :
I think it's not possible with text file.
Can you give me the macro for VB please ?
7 REPLIES 7
Message 2 of 8
Artur.Kosakowski
in reply to: mateaus
Try  the following one please:
            Dim ra As New RobotOM.RobotApplication
            Dim sc As RobotOM.RobotSimpleCase
            Dim rc As RobotOM.RobotLoadRecordDead
            sc = ra.Project.Structure.Cases.CreateSimple(10, "charge verticale", RobotOM.IRobotCaseNature.I_CN_PERMANENT, RobotOM.IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
            rc = sc.Records.Get(sc.Records.[New](RobotOM.IRobotLoadRecordType.I_LRT_DEAD))
            rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_COEFF, 0.2)
            rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_ENTIRE_STRUCTURE, 0)
            rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_Z, -1)
            rc.Objects.FromText("1 2 3 4 5")
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
Message 3 of 8
mateaus
I_DRV_COEFF doesn't exist. Is it new ? I don't have Robot Pro 2012, I have Robot Pro 2011.
My macro
Sub poids_propre_coef()
    Dim cas As RobotOM.RobotSimpleCase
    Set cas = Loads.Get(nocasdecharge)
  ' sc = ra.Project.Structure.Cases.CreateSimple(10, "charge verticale", RobotOM.IRobotCaseNature.I_CN_PERMANENT, RobotOM.IRobotCaseAnalizeType.I_CAT_STATIC_LINEAR)
    rc = sc.Records.Get(cas.Records.[New](RobotOM.IRobotLoadRecordType.I_LRT_DEAD))
 If coefx = 0 Then
    If coefz = 0 Then
    MsgBox "Pas de coef pour la charge de poids propre!", vbOKOnly + vbExclamation, "INVALID FOLDER"
    Exit Sub
    Else
'    rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_COEFF, coefz) = True
    rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_Z, DirZ) = True
    End If
 Else
' rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_COEFF, coefx) = True
 rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_X, dirx) = True
 End If
    rc.SetValue(RobotOM.IRobotDeadRecordValues.I_DRV_ENTIRE_STRUCTURE, 0) = True
    rc.Objects.FromText ("Tous")
End sub
Message 4 of 8
Rafal.Gaweda
replace
by
rc.SetValue(3, coefz)
Rafal Gaweda
Message 5 of 8
mateaus
This command doesn't work.
rc1.Objects.FromText ("1 2 3 4 5")
Dim Loads As RobotCaseServer
Set Loads = robapp.Project.Structure.Cases
'    Dim ra As New RobotOM.RobotApplication
    Dim cas As RobotSimpleCase
    Dim rc As RobotLoadRecordMngr
    Dim rc1 As RobotLoadRecordDead
  '  rc = cas.Records.Get(cas.Records.New(IRobotLoadRecordType.I_LRT_DEAD))
  Set rc = cas.Records
  i = rc.New(I_LRT_DEAD)
  Set rc1 = rc.Get(i)
 If coefx = 0 Then
    If coefz = 0 Then
    Exit Sub
    Else
    rc1.SetValue 3, coefz
    rc1.SetValue I_DRV_ENTIRE_STRUCTURE, 0
    rc1.SetValue I_DRV_Z, DirZ
'    rc1.Objects.FromText ("1 2 3 4 5")
    End If
 Else
 rc1.SetValue 3, coefx
 rc1.SetValue I_DRV_X, dirx
 End If
    Set rc = Nothing
    Set rc1 = Nothing
    Set cas = Nothing
End Sub
Message 6 of 8
Rafal.Gaweda
Try this:
rc1.Objects.FromText "1 2 3 4"
Rafal Gaweda
Message 7 of 8
mateaus
in reply to: Rafal.Gaweda
Ok but why this command doesn't work ?
rc1.Objects.FromText "tous"
Message 8 of 8
Rafal.Gaweda
This command should work in Frencha language version of ARSA
try this code for french and english:
rc1.Objects.AddText "tous"
rc1.Objects.AddText "all"
Rafal Gaweda
