Hello all,
I have strange problem with the shear stresses Tz on beams of a building I am working on it.
Namely, the shear stresses Tz are calculated as 0.00 for any load case, although there are shear forces Fz acting on the beams.
I noticed that the beams and columns I am inspecting are drawn by dashed lines, whereas other frames are drawn by solid lines (as I expect). The other frame from the same model I am attaching as an example has solid lines for the beams as well as shear stresses calculated.
Is this a problem with the GUI? Is this the problem why there are no shear stresses calculated?
File please.
Turn off Structural Axis display and check
