Custom rebar database
7 REPLIES 7
Message 1 of 8
1806 Views, 7 Replies
I cannot edit a custom reinforcing bar database. The Open button does not work. See attached video: http://screencast.com/t/3mrlqUinWph
7 REPLIES 7
Message 2 of 8
Rafal.Gaweda
Patrick
copy
"c:\Users\user_login\AppData\Roaming\Autodesk\Structural\Common Data\2012\bar_EC.xml"
to
"c:\ProgramData\Autodesk\Structural\Common Data\2012\Data\Reinf\bar_EC.xml
Rafal Gaweda
Message 3 of 8
Hi Rafal,
I have the same problem and coping the files didn't work.
What else should I do.
Gustavo
Message 4 of 8
Have you copied it to correct folder?
Make a movie like Partick did to show how it works on your comp.
Rafal Gaweda
Message 5 of 8
Dear Rafal,
see the link to the video:
http://www.screencast.com/t/g8WkSvHLvP07
Gustavo
Message 6 of 8
Gustavo,
Your problem is different, editor does not work at all.
Check whether you have this file on your comp or not?
c:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\RBCTMdbEditX.dll
If you have it on disk plaese open windows Command Prompt in Admin mode, and regiter this dll by the command shown below:
Rafal Gaweda
Message 7 of 8
Thank you!! It is working now!
Message 8 of 8
It worked!
