Discussion Groups
Robot Structural Analysis
Valued Contributor
Opel5
Curve fitting panels & auto update of panel polylines when node positions change
715 Views, 6 Replies
08-03-2012 01:02 AM
Morning All!
I'm looking to try and find the most efficient way of resolving the following two problems:
1) Curve fitting panels - Referring to the zipped RTD file attachment, I would like  add a 1.2m radius curved edge to the first "platform" down from the upper platform. The model is made up of nodes, then wrapping polylines around nodes to form the outline for the panels. Is there an option to explode a smooth arc of nodes to form the curved cantilevered platform edge which I can allocate to a SMOOTH curved panel (rather than a panel with jagged edge going from node to node of the arc).
2) Is there a way to auto update panels respective polylines when node positions change. Say for example if the stairs was stretched in 1 direction. Whenever I need to alter a node position I have to delete and re-draw the affected panels polyline, then allocate the panel again. I'm sure there must be a more clever way of going about it!
Any expert suggestions on efficiently solving the above is greatly appreciated :smileyhappy:
Scott
Please use plain text.
Product Support
Artur.Kosakowski
Re: Curve fitting panels & auto update of panel polylines when node position
08-03-2012 01:36 AM in reply to: Opel5
1) Please make a sketch that illustrate what you want to achieve
2)  See the attached picture
Artur Kosakowski
Valued Contributor
Opel5
08-03-2012 02:04 AM in reply to: Artur.Kosakowski
Hi Artur,
Please refer to the attached PDF sketch.
Scott
Product Support
Artur.Kosakowski
08-03-2012 02:45 AM in reply to: Opel5
1) Arch
2) What about defining an auxiliary Z axis?
Artur Kosakowski
Valued Contributor
Opel5
08-03-2012 03:01 AM in reply to: Opel5
That's perfect, thanks again Artur!
Valued Contributor
Opel5
08-06-2012 01:29 AM in reply to: Opel5
Morning Artur,
I've applied arch change to the mid platform but have been getting the error during verification of: "incoherent mesh on edges". It runs through the calculation stage and builds up the FE mesh but when checking required reinforcement for the curved platform there seems to be no analysis results for this area. I've checked the nodal edges between the curved panel and adjacent panels and there seems to be no gaps. Can you spot what is causing the error please?
Scott
Product Support
Artur.Kosakowski
08-06-2012 03:14 AM in reply to: Opel5
The model with corrected meshes.
Artur Kosakowski
