Dear Sir or Madam,
I'm trying to design a cubic tank through the Cubic Tank wizard. But when I put the informations and click apply/ok and error appears. Could you please help me to solve that out? I'm sendind attached a image and the error text. Thank you in advance.
Best regards,
Solved by Artur.Kosakowski. Go to Solution.
I think it is due to the material name C12/15 and despite the warning the object is created. Then you can change its thickness and material editing the thickness label or assigning a new one as shown below:
