Hi every body,
usually when modeling a stell deck or a composite slab of a steel frame building we can use :
1)pannels
2)Rlinks + bar or/cladding
3)cladding + bar + st andrew cross (bar also)
My question is about type 3, as st andrew cross works mainly in tension/comp, we usually put releases at both ends in order to avoid parasite moment. Many instabilities car appears because someone forgot to release all BUT ONE bars in for same node -> boring ..
The question is it equivlent to define the 2 diagonals working only in tension/compression with no release at the end to have diagonals with release non restriction about the efforts .. if it is I would be keen on using the first technique.
What do you think?
If they are not connected at their intersections then you can try to use truss bars instead.
