Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Criterions to Stop Analysis
5 REPLIES 5
skilak
420 Views, 5 Replies
I have performed a non-linear analysis on a double span continuous structure, using elasto-plastic steel beam properties and tried to use the "criterions to stop analysis" function. I can see that the function works but how can I figure out the condition at which it has stopped e.g.. load factor (the criteria has been achieved at 45% of the applied load)?
Thanks in advance for your kind help.
Best regards,
5 REPLIES 5
Artur.Kosakowski
in reply to: skilak
You can check this e.g. in the calculation report.
Artur Kosakowski
skilak
in reply to: Artur.Kosakowski
I have tried to get the results (rtf file) exactly as you but couldn't. Please could you do it on the attached file and explain whera and how I can create that file of the result calculations (printout composition seems not the way)? Thanks
Artur.Kosakowski
in reply to: skilak
Please check; http://forums.autodesk.com/t5/Robot-Structural-Analysis/Design-Calculation-Report/m-p/3630398
Artur Kosakowski
skilak
The calculation note is under "Analysis" not "Results" as instructed in your link; unless my Robot is different:smileywink:
Best regards,
Artur.Kosakowski
in reply to: skilak
I'm sorry - my mistake - I pointed you to the wrong topic which is about the note for RC design. I will edit it so that it doesn't confuse readers. Thank you for indicating this to me.
Artur Kosakowski
