Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Creative modol land
6 REPLIES 6
athurD
270 Views, 6 Replies
Creative modol land
Hi Robot could creative Modol land same Plaxis????
6 REPLIES 6
athurD
in reply to: athurD
Robot could do same Plaxis ???
Please.
Artur.Kosakowski
in reply to: athurD
I'm not sure if I understand you correctly but I assume that you want to model soil with solid elements. In Robot there are no special elements for modeling soil behavior and personally I'd rather use elastic supports instead (as in the sample model I sent you) but of course you can use solids if you think it is a better solution.
Artur Kosakowski
athurD
in reply to: Artur.Kosakowski
thanks Artur.Kosakowski
but I have not received your model.
Please send agian.
Artur.Kosakowski
in reply to: athurD
Please mind that the attached model is intended only as the example of use of solids.
Artur Kosakowski
athurD
in reply to: athurD
hi. thanks
Artur.Kosakowski
in reply to: athurD
As I mentioned this is just the sample solid model and you have to decide what is the best way of supporting the structure. In my sample model I defined supports in the directions perpendicular to each side of the solid (UZ for XY bottom side/ UX for YZ sides/ UY for XZ sides).
Artur Kosakowski
