Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Creation panel with FE list
8 REPLIES 8
Message 1 of 9
Romanich
1940 Views, 8 Replies
Hello friends,
When I change the thickness of panel by using option Creation with FE list, only  self weight has been applied to FE with new thickness. Other loads automatically not transfered. It's a bug or feature?
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Tags (2)
8 REPLIES 8
Message 2 of 9
in reply to: Romanich
Not sure but seems logical to me that loads would not be replicated as loads are normally "hosted" to the contour edge (my guess ?) which would have been re-defined by creating the new panel from elements.
Tony
Message 3 of 9
Romanich
Hi Tony,
Also existing loads (which has been applied to first FE) is inactive.
Roman Zhelezniak
Message 4 of 9
Ahhh so you create panel from FE's, add loads, then change thickness and loads dissappear?  Sounds like bug!
Like the one I get when I change thickness it defaults back to "Curtain Wall" and I have to make shell again
Message 5 of 9
Pawel.Pulak
It is "as designed" - when creating new panel from the list of finite elements the loads assigned to panels (where the lists of loaded panels are not automatically updated - see Note) are not inherited by the new one.
One of the reasons is that the list of finite elements can contain elements  from several adjacent panels. In such case it is not clear what to do when appropriate load is not applied to all of them.
Of course in practice (in more than 90% of cases I suppose) finite elements are taken from one panel. The improvement suggestion to inherit panel loads in such case was registered 🙂
Note:  the loads assigned to panels, where the lists of loaded panels are automatically updated, are self-weight load for "Whole structure" and the load on contour when "Automatic panel selection in the contour plane" is active
If this post answer your question please click "Accept as Solution". It will help everyone to find answer more quickly!
Pawel Pulak
Technical Account Specialist
Message 6 of 9
Romanich
in reply to: Pawel.Pulak
Pawel, thank you. Maybe this must be inclusive in help?
Roman Zhelezniak
Message 7 of 9
Pawel.Pulak
Roman,
the request to complete Help with his information was registered:)
Pawel Pulak
Message 8 of 9
you can video tutorial Creation panel with FE list????
Message 9 of 9
Pawel.Pulak
Here is the link to video I registered:
http://screencast.com/t/GxgtEue5bFf
Please notice that after the creation of panel from the list of finite elements the  FE meshes of the original and new panels are automatically frozen.
Pawel Pulak
