Example code creates 1FE panels from existing meshed panel
Modify it
Dim RSelection As RobotSelection Set RSelection = RobApp.Project.Structure.Selections.CreateFull(I_OT_FINITE_ELEMENT) Dim FECol As RobotFiniteElementCollection Dim Collection As RobotNumbersCollection Set FECol = RobApp.Project.Structure.FiniteElems.GetMany(RSelection) Dim OD As RobotObjObject Dim PT As String Dim RT As String Dim CM As String For i = 1 To FECol.Count Set OD = RobApp.Project.Structure.Objects.Get(FECol.Get(i).ObjectNumber) PT = OD.GetLabelName(I_LT_PANEL_THICKNESS) RT = OD.GetLabelName(I_LT_PANEL_REINFORCEMENT) CM = OD.GetLabelName(I_LT_PANEL_CALC_MODEL) Set Collection = RobApp.Project.Structure.Objects.CreateOnFiniteElems(Str(FECol.Get(i).Number), 100000 + i) RobApp.Project.Structure.Objects.Get(Collection.Get(1)).SetLabel I_LT_PANEL_THICKNESS, PT RobApp.Project.Structure.Objects.Get(Collection.Get(1)).SetLabel I_LT_PANEL_REINFORCEMENT, RT RobApp.Project.Structure.Objects.Get(Collection.Get(1)).SetLabel I_LT_PANEL_CALC_MODEL, CM Next i
Hi!
Do you have a similar example but for creation panels based on list of objects, not FE?
Thank you,
Gabi
There in no such method in API
robapp.Project.Structure.Objects.Create*
So either use CreateCountour using RobotPointsArray
or create contour like in this example (also Panel properties are assigned in the code below)
Sub Plaque_Robot() ' stockage des points des contours des panneaux tableau_point_int(1).X = 0# tableau_point_int(1).Y = 0# tableau_point_int(1).Z = 0# tableau_point_int(2).X = 20 tableau_point_int(2).Y = 0# tableau_point_int(2).Z = 0# tableau_point_int(3).X = 21 tableau_point_int(3).Y = 10 tableau_point_int(3).Z = 0# tableau_point_int(4).X = 1 tableau_point_int(4).Y = 10 tableau_point_int(4).Z = 0# ' ***** elements Robot ***** Dim monobjet As RobotObjObject Dim moncontour As New RobotGeoContour Dim monsegment() As New RobotGeoSegmentLine ' ************************** Dim i As Long 'contour carré donc 4 segments ' définition des segments ReDim monsegment(1 To 4) For i = 1 To 4 monsegment(i).P1.Set tableau_point_int(i).X, tableau_point_int(i).Y, tableau_point_int(i).Z ' initialisation des contours moncontour.Add monsegment(i) Next moncontour.Initialize 'création de l'objet panneau Set monobjet = robapp.Project.Structure.Objects.Create(1) monobjet.Main.Geometry = moncontour monobjet.Main.Attribs.Meshed = True ' Demande si le maillage doit ętre généré sur l'élément objet monobjet.Main.Attribs.DirZ = 0 ' axe local monobjet.Main.Attribs.SetDirX I_OLXDDT_CARTESIAN, 1, 0, 0 ' axe local monobjet.Initialize ' The function initializes internal data on the basis of the data defining the object. . monobjet.Update ' mise ŕ jour de l'objet ' maillage monobjet.Mesh.Params.MeshType = I_MT_USER monobjet.Mesh.Params.SurfaceParams.Method.Method = I_MMT_COONS monobjet.Mesh.Params.SurfaceParams.Generation.Type = I_MGT_ELEMENT_SIZE monobjet.Mesh.Params.SurfaceParams.Generation.ElementSize = 0.5 monobjet.Mesh.Generate ' définition du matériau Material_Name = "BETON" ' & Str(fc28) Set mat = robapp.Project.Structure.Labels.Create(I_LT_BAR_MATERIAL, Material_Name) Dim matdata As RobotMaterialData Set matdata = mat.Data matdata.Type = I_MT_CONCRETE matdata.E = 11000 * 30 ^ (1 / 3) * 1000000 ' matdata.E = 11000 * fc28 ^ (1 / 3) * 1000000 matdata.NU = 0 matdata.RO = 24530 matdata.Kirchoff = matdata.E / (2 * (1 + matdata.NU)) matdata.LX = 0.00001 matdata.RE = 30 * 1000000 ' matdata.RE = fc28 * 1000000 robapp.Project.Structure.Labels.Store mat ' Function saves the cut under the specified name sauvegarde des paramčtre sur le nom spécifique ' definition de l'épaisseur thick_name = "EP 30" Dim Label As RobotLabel Set Label = robapp.Project.Structure.Labels.Create(I_LT_PANEL_THICKNESS, thick_name) Dim ThickData As RobotThicknessData Set ThickData = Label.Data ThickData.ElasticFoundation = 0 ' appui elastique : ThickData.ElasticFoundation = coefficient_raideur * 9.81 * 1000 ThickData.ThicknessType = I_TT_HOMOGENEOUS ThickData.MaterialName = Material_Name Dim HomoThickData As RobotThicknessHomoData Set HomoThickData = ThickData.Data HomoThickData.Type = I_THT_CONSTANT HomoThickData.ThickConst = 30 / 100 robapp.Project.Structure.Labels.Store Label monobjet.SetLabel I_LT_PANEL_THICKNESS, thick_name Set Label = Nothing moncontour.Clear Set monobjet = Nothing Set moncontour = Nothing ReDim monsegment(1 To 1) Set monsegment(1) = Nothing End Sub
Gabi,
HINT: using BeginMultiOperation and EndMultiOperation in certain parts of code speeds up (several times) process of creating contours.
Example in http://forums.autodesk.com/t5/Autodesk-Robot-Structural/API-objects-geometry-to-triangles-converter/... in project source code.
