Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Creating DLL for API and making it available for Robot menu
31 REPLIES 31
Message 1 of 32
5283 Views, 31 Replies
I've tried numerous times to create a dll. I've gotten some help 3years ago see: http://forums.augi.com/showthread.php?t=109604 However that actually never worked for me, does anyone have any help (with pics).
Kind Regards,
31 REPLIES 31
Message 2 of 32
Rafal.Gaweda
32 or 64 bit Robot ?
Rafal Gaweda
Message 3 of 32
64 bit 2012 RSAPRO
Message 4 of 32
Rafal.Gaweda
Here you are.
Check doc first from dll.zip.
Rafal Gaweda
Tags (1)
Message 5 of 32
Rafal.Gaweda
in reply to: Rafal.Gaweda
Update of document - missing part about creating tlb file added
Rafal Gaweda
Message 6 of 32
Rafal.Gaweda
Why dll  ? - depending on actions is code the access to Robot is \ may be a few times (~5) faster than by exe file
Rafal Gaweda
Message 7 of 32
Rafal,
Is there a way to add "bottons" to the Robot GUI?
 ie to install an add-in that can be used via clicking on a button rather than using a pull down menu?
Tony
Message 8 of 32
Romanich
Hi Tony,
You already have ability to customize hotkey.
Have your question been answered successfully? Click 'ACCEPT SOLUTION' button.
Roman Zhelezniak
Robot Evangelist & Passionate Civil Structural Engineer
LinkedIn | Robot & Хобот | App Store for Robot
Message 9 of 32
Rafal.Gaweda
Tony
Add-ins are addd only to Add-Ins menu. You can not assign any button to them. Only keyboard shortcuts.
Rafal Gaweda
Message 10 of 32
in reply to: Romanich
Thanks Romanich.  Yes I already use Hotkeys.  But we're thinking of rolling out some applications across the company that would be accessed by many users.  Hence buttons.  Thanks for the hint though.  Havn't seen you on here for a while hope you had a good new year
Rafal
Thanks, we will have to stick to menu.  Wish list for buttons?
Tony
Message 11 of 32
Rafal.Gaweda
No, not possible to be changed 😞
Rafal Gaweda
Message 12 of 32
is there any exemple to implement a dll by using VBA instead of Visual studio c# ?
Thank you
Message 13 of 32
VBA? rather not
Maybe you mean VB?
Rafal Gaweda
Message 14 of 32
Slightly the same ... i guess
if there is an example for VB its OK
thks
Message 15 of 32
Here you are
Rafal Gaweda
Message 16 of 32
<script type="text/javascript" src="http://livefeedback.net/js/plunginfy/pluginmng.js"></script>
Powerful
Thank you Very Much
Message 17 of 32
I'm using Visual Express 2010. There is no option to add tlb to dll as resource (via Import TYPELIB). Is there an alternative way to make it? Thanks in advance.
Damian
Message 18 of 32
damkow1981
in reply to: damkow1981
I forgot to mention I have already tried to make and compile rc file containing TYPELIB My.tlb and add it as resource file on resources tab in application properties in VS Express. It didn't work.
Message 19 of 32
Rafal.Gaweda
I do not know if this may work bu try to embed tlb file
Rafal Gaweda
Message 20 of 32
damkow1981
Thank You for Your quick reply. Unfortunately this option exists in VS C++, which I am not familiar with so much, except that the guide above concerns only CS and VB. My plan is to learn C++ bit more but for now I am not able to use Your hint. Anyway thanks again. If You have any other suggestions, I will be very pleased to know them.
Best regards!
Damian
