PUEDE RESULTAR EN UN PANEL CON DIFERENTES MATERIALES?.
AUNQUE REALISO PANEL Y LE DE MISIONES CARACTERÍSTICAS DE UN VIDRIO, puedo crear un AISLADO QUE SE ESTABLECE UN VIDRIO 6MM + LAMINADO 1MM + UN VASO DE 9MM PARA MENSIONAR un tipo genérico ESTO ES POSIBLE EN ROBOT Y COMO LO QUE PUEDO HACER.
SALUDOS
Solved by Artur.Kosakowski. Go to Solution.
Check http://forums.autodesk.com/t5/Robot-Structural-Analysis/Modeling-complex-walls/m-p/5154790
After having posted the question, I came across this solution, now you generate a doubt.
The answer you generate me would be an equivalent to the work being developed by the panel.
I ask because, if I am faced with compounds well insulated by elements 6 MM + air space 12.7MM + another element 9 MM. would have to make an equivalence Indica so I, Robot does not allow me to enter the characteristics of each component (dimension and material) and perform an analysis of the 3 components working together, as presented in Revit or Ecotect Analysis.
But of the 3 options you present me:
1. Understand and would be performing an equivalence to assign the material to the required dimensions.
2. If I place the 3 or 2 panels linked rigid braces which would be placed on panel (s).
3. If you indicate as well I work with different thicknesses but not with one of items.
I don't think that either of them transfers this definition into the elements of the stiffness matrix
For determining the exact behaviour of such composite panel you would probably need to look for some specialized program - in Robot you have to decide on one of these simplified approaches.
Y cual es el programas mas avanzado que me comentas.
actualmente estoy trabajando con similitudes entre materiales.
You may look at Simulation Mechanical, Nastran, Ansys etc.
Good day. I still do not understand whether it is possible to calculate the deflection of a double-glazed window in a robot? The calculation of a single glass is possible - the robot considers it as a thin plate (Navier's solution). But how can a double-glazed window be calculated - when we have several layers of glasses interconnected through spacers along the perimeter of the glass. Who will suggest a solution?
For example, consider glass 8 mm thick, 1820 mm wide, 2420 mm high. Load 520 Pa. (see attached file and screenshot). Along the perimeter, the glass enters the window or facade profile by 15 mm and is thus fixed in the structure. The Robot shows a glass deflection of 11.2 mm. For single glazing, the calculation is correct.
But if we use a double-glazed window. The double-glazed window consists of two panes interconnected by a spacer (20 mm) along the glass perimeter, there will be air between the panes. How will glass deflection change? How can such a multilayer element of several glasses be calculated in the Robot?
You may calculate the equivalent thickness according to this Saint Gobain document (page 502).
I don't know if there is an English version
Not so obvious
I don't know if the thicknesses found here can be used in a robot model.
Consult your glazing code
For double and triple glazing see image below.
