I reinforced beam and column with Robot and I would like export this reinforcement to ASD with brazilian drawing norms.
Do you know how to create a template in ASD to import the drawing like I would.
Attache : An example of brazilian drawing.
Infact, I would like the negative reinforcement it is placed automaticly under the beam´s form and the positive reinforcement automatic up the beam´s form. I kown that the editing mode put the reinforcement outside of the beam/ column form but I didn´t find how to modify this mode too.
If there are a way to do this, it should be really good.
Thanks for the help.
Regards
Dear EduRJ,
try to use the Italian or French template at ASD.
The Italian one (RBCR_039.dwt) is very similar with the Brazilian.
Gustavo
