Robot Structural Analysis Forum
Welcome to Autodesk’s Robot Structural Analysis Forums. Share your knowledge, ask questions, and explore popular Robot Structural Analysis topics.
Create steel section with double UPN flange to flange
1 REPLY 1
Pousin1970
1040 Views, 1 Reply
When a double section UPN flange to flange is defined, importing from database a simple shape, not all the fields of the new mechanical and geometric characteristics are auto-filled.
Also, only a double section (for example, double UPN 120 can be save into a new catalogue).
Is it posible to define this section type and, after save into a catalogue "User", get all de existing dimensions (2UPN120, 2UPN140,....) with only the height given?
Thanks in advance
1 REPLY 1
If you mean such shape as below you can use the compound tab of the New Section dialog
Artur Kosakowski
