When a double section UPN flange to flange is defined, importing from database a simple shape, not all the fields of the new mechanical and geometric characteristics are auto-filled.
Also, only a double section (for example, double UPN 120 can be save into a new catalogue).
Is it posible to define this section type and, after save into a catalogue "User", get all de existing dimensions (2UPN120, 2UPN140,....) with only the height given?
Thanks in advance
Solved by Artur.Kosakowski. Go to Solution.
If you mean such shape as below you can use the compound tab of the New Section dialog
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
