Dear Colleagues!!
I am trying to create steel connection via Robot API, but with no result. Please help! I have already tried "Create" method from an interface IRobotProjectComponentMngr and a "Create" method from IRJointConnection interface. I also tried to use "SetToRobot" method from IRJointConnection interface after creating connection with the methods as above. No result. This is the code I wrote:
Dim r As IRobotApplication r = New RobotApplication Dim połączenia As IRJointConnectionServer połączenia = r.Project.Connections Dim połączenie As IRJointConnection połączenie = połączenia.Create(IRJointConnectionType.I_JCT_BEAM_COLUMN) Dim danePołączenia As RJointConnectionInfo danePołączenia = New RJointConnectionInfo danePołączenia.Name = "Połączonko" danePołączenia.DefType = IRJointConnectionDefType.I_JCDT_STANDALONE połączenie.SetToRobot(danePołączenia)
I suspect the error lies somwhere in the variable "danePołączenia". Please find enclosed printscreen. I will be very thankful for Your support.
Damian Kowalski
Kompletna procedura do tworzenia połaczenia STANDALONE Belka-słup na kątowniki Wystarczy przekopiować Public Sub CreateWithAngles() Dim RobotApp As New RobotApplication Dim WithAngles As RJointBeamColumn Dim jointServer As RJointConnectionServer Set jointServer = RobotApp.Project.Connections Set WithAngles = jointServer.Create(I_JCT_BEAM_COLUMN) With WithAngles Select Case ColumnPosition Case TO_WEB_COLUMN .ElementType = I_JBCET_ANGLES_WEB Case TO_FLANGE_COLUMN .ElementType = I_JBCET_ANGLES_FLANGE End Select End With 'PROCEDURES ------------ JointProfiles WithAngles //procedury zdefiniowane JointWithAngles WithAngles //procedury zdefiniowane '----------------------- Dim JointInfo As RJointConnectionInfo Set JointInfo = jointServer.CreateInfo JointInfo.DefType = I_JCDT_STANDALONE JointInfo.Type = I_JCT_BEAM_COLUMN JointInfo.Number = 0 WithAngles.SetToRobot JointInfo Dim load As New RJointBeamGirderLoad load.Cases.FromText "" If NumberSides = TWO_SIDES Then load.LFx = 1000# load.LFz = 3000# load.LMy = 0# End If load.RFx = 1000# load.RFz = 3000# load.RMy = 0# Ratio = jointServer.CalculateNote(NumberJoints, load, NotePath) ‘ lblRatio.Caption = CStr(Ratio) Set WithAngles = Nothing Set load = Nothing Set JointInfo = Nothing Set jointServer = Nothing End Sub Public Sub JointWithAngles(ByRef AJoint As RJointBeamColumn) With AJoint 'ELEMENTS ------------------------------ If NumberSides = TWO_SIDES Then .AngleLeft.Element.Profile.Section = "LR 100x100x10" .AngleLeft.Element.Profile.Material = "STAL" .AngleLeft.Element.Length = 130# .AngleLeft.Element.DistFromUpperBeamEdge = 85# .AngleLeft.Element.ProfilePosition = I_JAPP_LONG_FLANGE_TO_COLUMN End If .AngleRight.Element.Profile.Section = "LR 100x100x10" .AngleRight.Element.Profile.Material = "STAL" .AngleRight.Element.Length = 130# .AngleRight.Element.DistFromUpperBeamEdge = 85# .AngleRight.Element.ProfilePosition = I_JAPP_LONG_FLANGE_TO_COLUMN '--------------------------------------- '-----------BOLTS ----------------------------------- If NumberSides = TWO_SIDES Then .AngleLeft.BoltsMain.ClassName = BeamcolumnMainForm.cboBoltsClass.Text .AngleLeft.BoltsMain.DiameterName = BeamcolumnMainForm.cboBoltsDiameter.Text .AngleLeft.BoltsMain.Rows = 2 .AngleLeft.BoltsMain.Cols = 2 .AngleLeft.BoltsMain.SpacingV = 60# .AngleLeft.BoltsMain.SpacingH = 60# .AngleLeft.BoltsMain.Friction = 0.3 .AngleLeft.BoltsMain.DistFromUpperElementEdge = 35# .AngleLeft.BoltsMain.DistFromVertElementEdge = 65# .AngleLeft.BoltsBeam.ClassName = BeamcolumnMainForm.cboBoltsClass.Text .AngleLeft.BoltsBeam.DiameterName = BeamcolumnMainForm.cboBoltsDiameter.Text .AngleLeft.BoltsBeam.Rows = Rows .AngleLeft.BoltsBeam.Cols = Cols .AngleLeft.BoltsBeam.SpacingH = 60# .AngleLeft.BoltsBeam.SpacingV = 60# .AngleLeft.BoltsBeam.Friction = 0.3 .AngleLeft.BoltsBeam.DistFromUpperBeamEdge = 35# .AngleLeft.BoltsBeam.DistFromVertBeamEdge = 65# End If .AngleRight.BoltsMain.ClassName = BeamcolumnMainForm.cboBoltsClass.Text .AngleRight.BoltsMain.DiameterName = BeamcolumnMainForm.cboBoltsDiameter.Text .AngleRight.BoltsMain.Rows = 2 .AngleRight.BoltsMain.Cols = 1 .AngleRight.BoltsMain.SpacingV = 60# .AngleRight.BoltsMain.SpacingH = 60# .AngleRight.BoltsMain.Friction = 0.3 .AngleRight.BoltsMain.DistFromUpperElementEdge = 35# .AngleRight.BoltsMain.DistFromVertElementEdge = 65# .AngleRight.BoltsBeam.ClassName = BeamcolumnMainForm.cboBoltsClass.Text .AngleRight.BoltsBeam.DiameterName = BeamcolumnMainForm.cboBoltsDiameter.Text .AngleRight.BoltsBeam.Rows = Rows .AngleRight.BoltsBeam.Cols = Cols .AngleRight.BoltsBeam.SpacingV = 60# .AngleRight.BoltsBeam.SpacingH = 60# .AngleRight.BoltsBeam.Friction = 0.3 .AngleRight.BoltsBeam.DistFromUpperBeamEdge = 35# .AngleRight.BoltsBeam.DistFromVertBeamEdge = 65 '----------------------------------- End With End Sub Public Sub JointProfiles(ByRef AJoint As RJointBeamColumn) With AJoint 'COLUMN ----------------------- .Column.Section = BeamcolumnMainForm.cboColumnProfile.Text .Column.Material = BeamcolumnMainForm.cboColumnMaterial.Text '------------------------------------ '--- BEAM_LEFT ---------------------- If NumberSides = TWO_SIDES Then .BeamLeftExist = True .BeamLeft.Section = BeamcolumnMainForm.cboBeamLeftProfile.Text .BeamLeft.Material = BeamcolumnMainForm.cboBeamLeftMaterial.Text End If '---- BEAM_RIGHT ----------------- .BeamRight.Section = BeamcolumnMainForm.cboBeamRightProfile.Text .BeamRight.Material = BeamcolumnMainForm.cboBeamRightMaterial.Text '--------------------------- If NumberSides = TWO_SIDES Then .DistColumnToBeamLeft = 15# End If .DistColumnToBeamRight = 15# End With End Sub
Could You please send such a piece of code for a connection defined on structure elements? Thank You in advance!!
Dear @Rafal.Gaweda,
following this old post...
Could you explain the first part of the code to define a base plate connection in VBA?. It is being so hard for me to define the first lines of the code. I have the following, but I have not knowledge enough to continue:
Sub placa() Dim RobotApp As New RobotApplication Set RobotApp = New RobotApplication Dim prj As IRobotProject Set prj = RobotApp.Project prj.New I_PT_STEEL_CONNECTION Dim unionServer As IRJointConnectionServer Set unionServer = RobotApp.Project.Connections End sub
Thank you in advance.
