Create my own NDS code
5 REPLIES 5
446 Views, 5 Replies
Is there a way I can create and use NDS code for timber design?
I am interested in testing this product, but do not like the fact that there is no NDS code for timber design, and the connection module does NOT have an american code.
Terry
5 REPLIES 5
Priitl220
You can use spreadsheet calculator (MS Excel addin). Define you own deign checks and pull other information form robot (like section information, internal forces and etc.)
____________________________________________
If you find my post useful give me Kudos. Thank you!
If my post solved your problem, accept it as a solution.
Artur.Kosakowski
I'm attaching a sample view of one of the timber connection modules of Spreadsheet Calculator (available for download from Autodesk Subscription site) . Starting a new workbook from the Add-Ins tab  (available after installing Robot) you can use the predefined tools for importing data from Robot. The description of the API as well as the corresponding examples are available in the indicated folder after installing Robot.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
Artur Kosakowski
in reply to: Artur.Kosakowski
Well, I am in trial mode, and Subscription features are not available..........
I found a few videos on Youtube from May 2010.  Will these be adequate, or were there substantial updates to that extension ???
Terry
Priitl220
It has not been improved much (not that I have noticed). But it is ready.
Check this site also http://www.esopworld.com/n/esop/en
(it was called ESOP before Autodesk time).
It makes it much easier to connect with Robot than using plain Excel and VBA.
Artur.Kosakowski
NDS code has been introduced in Robot 2016.
Artur Kosakowski
