Crack width calculation for reinforced concrete
26 REPLIES 26
Message 1 of 27
6504 Views, 26 Replies
Guy's
I am trying to get detailed calculations for crack widths in RSA, although I input limiting crack widths in the reinforcement calculations, I wondered if there was a detailed output given by robot without going into the spreadsheet calculator extension.
Further I have veiwed the 2 youtube tutorials on the spreadsheet calculator, and was wondering if there are any further tutorials or learning material for it.
Thanks again.
Gavin
26 REPLIES 26
Message 2 of 27
Rafal.Gaweda
Which module we are talking about?
Which code?
Rafal Gaweda
Message 3 of 27
in reply to: Rafal.Gaweda
I shall  explain a bit better,
I am using robot structural analysis 2011 and trying to complete SLS calculation for a concrete structure, in this case I have a test model in which I have designed the reinforcement asigned a limiting crack width of 0.2mm but would like to see the crack width calculations from robot.
The code we are using is BS 8110 but ussually our carck width calculations conform to BS 5400.
Best Regards
Gavin
Message 4 of 27
Rafal.Gaweda
RC slab deflections in Robot according to BS 8110.
Concrete creeping coefficient (creep coefficient) fi - specified by the
user or calculated automatically (taking into account effective section
thickness) according to Figure 7.1 in BS 8110
Concrete age (loading moment) - used in calculations of creep
coefficient (Figure 7.1 in BS 8110) and modulus of elasticity of
the concrete (part 7.2 of BS 8110)
Relative environment humidity - used in calculations of creep
Part of loads: variable long-term - starting from v.14.5 it means what part of live load can
be treated as long-term load (the rest is treated as short-term). This
coefficient equal to 1 means that all dead and live loads are long-term
loads. This coefficient equal to 0 means that all dead loads are
long-term loads and all live loads are short term loads.
Up to v.14.0 above coefficient related not only to live loads but to all
loads (including dead loads)
Deflections are calculated using point 3.6 of code and Figure 3.1. Moreover some methods
described in Chapter 5 of the following handbook are used: F.K.Kong, R.H.Evans,"Reinforced
and Prestressed Concrete", 3rd edition, Van Nostrand Reinhold (UK) Co. Ltd. 1987
For short-term loads the short-term modulus of elasticity of the
concrete Ec is used when calculating deflections (in practice Ec28).
For long-term loads the effective modulus of elasticity of the concrete
Eff=Ec/(1+fi) is used when calculating deflections.
Total deflection is calculated as the sum of above ones.
Parts 7.4 of BS 8110 is not taken into account.
Rafal Gaweda
Message 5 of 27
Thank you for this information Rafal thats great, does robot output detailed calcs of crack width, and if so how is this done?
Message 6 of 27
Rafal.Gaweda
No, there is no detail calcs  in notes of rc modules.
There are all final results there
Rafal Gaweda
Message 7 of 27
stroxy
I like this ... Can you give me the same breakdown for EC2?
Message 8 of 27
Thank you Rafal for your help,
I will use the spread sheet calculator to bring out the results, have you any additional tutorial material on the spreadsheet calculator?
If so could you point me in the right direction.
Best Regards
Gavin
Message 9 of 27
Rafal.Gaweda
  spread sheet calculator to bring out the results? What do you mean by that ?
Rafal Gaweda
Message 10 of 27
I have ran the reinforcement design in robot, but would like to extract the design data from robot and use it to produce a detailed crack width calculation, I will complete this on a excel sheet we use in the office.
My intension is to use the various functions in the Robot addon, spreadsheet calculator (SC) to take the relavent data from my robot model and use it in this spread sheet.
What I was looking at doing was trying to extract things like reinforcemnt diameters, fyk for steel etc directly from the robot model and into my crack width spreadsheet so that when the design was completed on Robot it could be cross checked and a detailed design calc could be produced also. Do you have a copy of the SDK for robot so make it easier for us to extract the relavent data.
We have a copy Kong and Evans, which I have now researched and will use this as the basis fo my detailed calculation in SC.
I note there has been a request for a "RC slab deflections in Robot according to BS 8110" but according to EC 2 could you provide that as I wish to update our system here to EC 2 and that would help in the transition.
Once again thank you for all the assistance it is a great help.
Best regards
Gavin
Message 11 of 27
Rafal.Gaweda
I recommend ordinary Excell + Robot API
SDK installation on your DVD. If not, SDK in unpacked version here:
http://www.megaupload.com/?d=XM699PPN
In different way: code paragraphs, formulas, tables not implemented in RC EC2 design:
2.5 Design assisted by testing
2.7 Requirements for fastenings
3.1.5 Stress-strain relation for non-linear structural analysis
3.1.9 Confined concrete
3.2.6 Fatigue
3.3 Prestressing steel
3.4 Prestressing devices
5.6 Plastic analysis
5.7 Non-linear analysis
5.8.3 Simplified criteria for second order effects
5.8.6 General method
5.9 Lateral instability of slender beams
5.10 Prestressed members and structures
6.2.5 Shear at the interface between concretes cast at different times
6.3.3 Warping torsion
6.5 Design with strut and tie models
6.7 Partially loaded areas
8.7.3 Lap length
8.7.4 Transverse reinforcement in the lap zone
8.9 Bundled bars
8.10 Prestressing tendons
9.6 Walls
9.7 Deep beams
9.8.1 Pile caps
9.9 Regions with discontinuity in geometry or action
9.10 Tying systems
10. Additional rules for precast concrete elements and structures
11. Lightweight aggregated concrete structures
12. Plain and lightly reinforced concrete structures
Annexes:
F (Informative) Reinforcement expressions for in-plane stress conditions
G.2 (Informative) Soil structure interaction
H (Informative) Global second order effects in structures
I (Informative) Analysis of flat slabs and shear walls
J (Informative) Examples of regions with discontinuity in geometry or action
Limitations:
- theoretical RC calculations :
  calculation model of concrete - no choice, always a rectangle
  calculation model of steel - no choice, always perfectly elastic-plastic (flat plastic branch)
 provided reinforcement for slabs
  Punching - forces applied within the penetration zone not considered, except for concentrated forces aplied on the same node as the support (by analogy to other standards)
  Punching - only for the dimensioning of ULS (by analogy to other standards)
  Punching - dimensioning is carried out for only one combination, this occurs for which the largest axial force, although in the calculation comes to interaction with the bending moments (similarly to other standards)
  Punching - dimensioning slabs or columns with heads - lack of double bar-critical circuits (by analogy to other standards)
  [9.10] Systems binding and wreaths
Rafal Gaweda
Message 12 of 27
I have few questions:
IN CALCULATION NOTE FOR RC BEAM, WHAT IS WHAT:
2.5.5 Deflection and cracking
wt(QP) Total due to quasi-permanent combination - LONGTERM DEFLECTION IN  t=∞ ?
Dwt(QP) Deflection increment from the quasi-permanent load combination after erecting a structure. INSTANT DEFLECTION IN t=0 ?
wk - width of perpendicular cracks - WHICH CRACKS, LONGTERM (t=∞) OR SHORTTERM (t=0)?
Which code combination does it uses for crack width calculation? SLS -  QP?
If this solved your issue, please Accept it as Solution help other forum users with similar issues to find answers easily.
Mirko Jurcevic
My blog: www.engipedia.com
Try my Revit add-ins: Autodesk App Store
Message 13 of 27
Ad1 Yes,„Long term deflection (t=inf) due to quasi-permanent combination”
Ad2 Deflection as described :
EN 1992-1-1:2004 7.4.1
(5) Deflections that could damage adjacent parts of the structure should be limited. For the
deflection after construction, span/500 is normally an appropriate limit for quasi-permanent
loads. Other limits may be considered, depending on the sensitivity of adjacent parts.
(Long term deflection increase depends on QPR loads after building errection)
Ad3 long term cracks:
EN 1992-1-1:2004 7.3.1
(5) A limiting calculated crack width, wmax
it may be assumed that limiting the calculated
crack widths to the values of wmax given in Table 7.1N, under the quasi-permanent combination of loads,
Rafal Gaweda
Message 14 of 27
Thank you Rafal. I just wanted to be sure.
Still, it's to bad that we cannot control what's Robot doing, it would be nice that we can check what value Robot uses in each variable, either that or good verification manual so we don't have to ask this kind of questions. This way, we have to 'trust' Robot uses right values and right formulaes.
I have manually calculated an example of T-beam, and results are different from those Robot gives me:
ROBOT:
  wt(QP)=23,70mm
  Dwt(QP)=15,33mm
  wk=0,25mm
Manual:
  wt(QP)=27,9mm
  Dwt(QP)=19,0mm
  wk=0,22mm
As you can see, differences are from 13% to 24%.
I already wrote on other forum thread that I can't find verification manual for v2014.
Mirko Jurcevic
Message 15 of 27
File please + scan of your manual calcs please.
Rafal Gaweda
Message 16 of 27
I've sent you private message.
Mirko Jurcevic
Message 17 of 27
Mirko,
First part of answer - cracks (basing on model and documents you sent me):
In fact rebars are loacated 2mm beloww the level you assumed:
but it does not give significant difference.
According to your book example explanations, our understanding of Slovenian language + googletranslate...
we see this
we understood that c is calulated as     d  -   1/2*rebar_diam    -   transversal_rebar_diam
so it is cover to transversal rebar
But according to EC2 7.11
so this difference gives srmax 209mm instead of 190mm and thus 0.25mm cracks instead of 0.22mm.
Rafal Gaweda
Message 18 of 27
hi,
Which version of MS Office do you guys use? I have tried with 2007, but without any luck. Do I have to enable or disable something to get spread sheet working.
Message 19 of 27
..it's Croatian language, not Slovenian. They are similar but very different. 😉
That's correct.
But according to EC2 7.11....
Yes, I've cheked in my Croatian version of EC2, that correct too. I didn't pay attention to it before.
Usually, when we calculate reinforced concrete, and someone says cover "c", we all assume that's distance from face of concrete to the first reinforcement bar.
This may be an error. I will check this with the author of the book.
Thank you very much Rafal !
Hope to see the rest of it soon.
Mirko Jurcevic
Message 20 of 27
Mirko.Jurcevic
If you are referring to Robot extension Spreadsheet caculator then it is assumed that you must enable macros to make it work.
Look here:
http://grok.lsu.edu/article.aspx?articleid=6144
I didn't use those spreadsheets much, though.
Mirko Jurcevic
