Mr Robot,
I am trying to model a multi storey building and I am experiencing unusual results regarding the disoplacements of the core walls. As you can see in the attached screenshot, the columns are being compressed slightly under the loading of the many storeys, but in contrast the core walls are been showing as moving upwards. Is there any logical explanation for this?
I have checked the reactions at the base and there is no sign of any uplift occuring.
There is no wind load applied, just dead + imposed at this stage.
Jon
Solved by Artur.Kosakowski. Go to Solution.
Jon,
Local z is in the direction perpendicular to the panel. Check
instead.
If you find your post answered press the Accept as Solution button please. This will help other users to find solutions much faster. Thank you.
